[GRASSLIST:3738] Re: problem import shape file
Radim Blazek
blazek at itc.it
Fri May 24 06:33:00 EDT 2002
On Thursday 23 May 2002 08:55 pm, Marco Kienzle wrote:
> Hi,
> I am having many problems trying to import a .shp file (from ESRI) using
> v.in.shape command although if the input file is a simple grid. The
> problem is that in the resulting file many polygons have a area equal to
> zero ??
> I import the file with the following commands:
> v.in.shape -o input=/home/kienzle/GIS/GRASS/poubelle/icesshape.shp
> attribute=JOIN label=ICESSQ
> Receive many of the following warnings:
> WARNING: area 375 label: 1059 matched another label: 1059.
> WARNING: area 406 label: 1060 matched another label: 1060.
> WARNING: area 437 label: 1061 matched another label: 1061.
> WARNING: area 468 label: 1062 matched another label: 1062.
> WARNING: area 499 label: 1063 matched another label: 1063.
> WARNING: area 530 label: 1064 matched another label: 1064.
> And then check for the result with
> v.report map=icesshape type=area units=k
> Am I doing something wrong ? Is there something wrong in the original
> file (although it works under ARC-INFO)?
> thanks in advance,
> marco
I tested. Import without errors, v.support:
Number of lines: 2660
Number of nodes: 1365
Number of areas: 1296
Number of isles: 1
Number of atts : 1296
Number of unattached atts : 0
Snapped lines : 0
v.report : all areas > 0, with the same value.
Radim
