[GRASSLIST:4943] Grass5_pre4 on OSX Jaguar
maxo
maxo at freemail.it
Wed Nov 13 08:37:03 EST 2002
I'm trying to install GRASS5-PRE4 on OSX 10.1.2.
I use bash as default terminal application.
I run the installatin script with success. After the installation I
entered in the bash the command line
source /etc/csh.cshrc /etc/csh.login
and it return me this message:
bash: /etc/csh.cshrc: line 11: syntax error: unexpected end of file
so I tryed to run the command in the tcsh and it seems to work (but I'm
not sure about this because I didn't recive any message after the
command.
After the installation I run grass5. The welcome message appear, but
when I hit return to continue I got this message:
Error opening terminal: vt100.
Invalid resource file, removing /var/root/.grassrc5
Both in bash and in tcsh.
I hope that someone could help me.
maxo
