[GRASSLIST:5074] Re: r3out.v5d(?) problem
Eric G. Miller egm2 at jps.net
Mon Nov 25 21:59:38 EST 2002
On Mon, Nov 25, 2002 at 05:59:03PM -0800, John Harrop wrote:
> I just regridded (s.vol.v5d) with a grid using equal number of row and
> columns (but not depths).  Now it works, although I'm still checking to
> see if its mirrored or otherwise messed up.  I usually assume that my
> code (s.in.ubcgif in this case) is causing the problems.  But then
> showdspf should not be working.
Note: The number 1 reason r3 code is not compiled by default has to do
with a discrepancy in row/col handling between regular rasters and
grid3d rasters.  Nobody has stepped forward to fix the problem...
"...the plural of anecdote is [not?] data."  - attrib. to George Stigler
