[GRASSLIST:4617] Re: Use of -i option in m.in.e00
Michel Wurtz
mjwurtz at wanadoo.fr
Tue Oct 1 14:20:38 EDT 2002
Radim Blazek wrote:
> I think, that feature-ID is closer to the category (dig_att) in GRASS. If
> more lines in e00 have the same feature-ID (i.e. one object consists of more
> graphic elements) we want to get the same in GRASS. Otherwise dig_cat
> (database record) would be duplicated, which is not desired. The link map->db
> should be many-to-one in this case.
The first implementation of m.in.e00 was using feature-ID, and I agree with you.
The problem comes from the info tables, where feature-# is used for linking graphic
objects and attributes. So you can have multiple entries for one feature-ID
(where some fields, like perimeter or surface, different). It is then safer to use
feature-#, except when the feature-# is just what you want in dig_att (like Z value
of contour lines...)
Here you can see that the design of Grass and Arc/Info is different, and that Grass
lacks a good attribute management system for vectors...
Michel.
