[GRASSLIST:4635] Re: GRASS 5.0.0 on OS X Jaguar (10.2.1)
Dennis Flanigan
dennis.flanigan at mesanetworks.net
Thu Oct 3 19:15:14 EDT 2002
Scott-
I have Grass5 running under Jaguar on a G4. The binaries (5pre4)
on the Grass web site really don't work well for 10.2, so I downloaded
the source code and compiled using the gcc that came with Jaguar/10.2.
I essentially had a clean system before I started this process.
Please note that I am new to GRASS, everything I have tried
seems to work so far, but when it comes to GRASS, I am still
at the "poking at it" stage.
I have not fooled with the database stuff yet....
Source Code:
I got the latest and greatest using CVS, but I am sure the tar file
with the source code will work as well. I followed the instructions
on the GRASS website for getting the code using CVS.
MAKE THIS CHANGE:
(From Glynn Clements on the developers mailing list)
Change the corresponding lines in src/CMD/generic/make.mid
DEPEDITLIB = $(LIBDIR)/libedit.a
EDITLIB = -ledit
to:
DEPEDITLIB = $(LIBDIR)/libgedit.a
EDITLIB = -lgedit
XDarwin
I was already using XDarwin before I upgraded to 10.2. I had to install
a patch for XDarwin to work under 10.2. The X11 package is installed
in /usr/X11R6. I am also using OroborOSX for the window manager.
FinkCommander
When I installed these libraries I was already up to 10.2. If you
originally compiled/installed libraries in 10.1.x, I would suggest
you recompiled
them all. Fink likes to install libraries and such in /sw . Using
FinkCommander
I compiled and installed these libraries:
fftw (fftw seemed to take a long time to compile)
gzip
libjpeg
libtiff
libpng
zlib
tcltk
gd
freetype2
I think that was a complete list. Unfortunately I didn't take notes
on this part. Someone please correct me if I am wrong.
configure
I used this configure command:
./configure --with-includes=/sw/include -- with-libs=/sw/lib
--with-opengl-includes=/usr/X11R6/include
--with-opengl-libs=/usr/X11R6/lib --with-postgres=no --with-odbc=no
To compile:
make >& make.log
I am using tcsh. The >& redirects both standard out and standard
error to the file make.log.
To install:
make install
And it work !
Good Luck
-Dennis Flanigan
