[GRASSLIST:4700] RE: Categories in v.in.dxf
Antonio Uriarte
antoniouriarte at terra.es
Thu Oct 10 16:39:53 EDT 2002
Hello, Miha.
I am not sure if there is the "category" option in v.in.dxf. I told you for
trying.
Anyway, I'm going to find out how v.in.dxf works and I'll tell you.
I think you will know the GRASS manuals that are in the GRASS official web
page. They explain each function very well.
Antonio Uriarte.
----- Original Message -----
To: <grasslist at baylor.edu>
Sent: Thursday, October 10, 2002 11:24 AM
Subject: [GRASSLIST:4699] RE: Categories in v.in.dxf
> Hi, Antonio
> Thanks for the tip, but are you completely sure that "v.in.dxf" has a
> parameter like "category"? I looked in all the helps of Grass5.0.0. (if
> there may be any difference) and they do not mention it. I also tried the
> command with your suggestion on blind and it did not work. The program
> outputs a message like "sorry, there is no parameter named category".
> Miha Staut
> >I think that there is an option "category=", isn't there? Try with
> >category=Layer or category=Elevation.
> >Antonio Uriarte.
> _________________________________________________________________
> MSN Photos is the easiest way to share and print your photos:
> http://photos.msn.com/support/worldwide.aspx
