[GRASSLIST:4703] RE: Categories in v.in.dxf
Markus Neteler
neteler at itc.it
Fri Oct 11 04:42:57 EDT 2002
On Thu, Oct 10, 2002 at 10:39:53PM +0200, Antonio Uriarte wrote:
> Hello, Miha.
> I am not sure if there is the "category" option in v.in.dxf. I told you for
> trying.
> Anyway, I'm going to find out how v.in.dxf works and I'll tell you.
> I think you will know the GRASS manuals that are in the GRASS official web
> page. They explain each function very well.
> Antonio Uriarte.
a good trick is to use the 'help' parameter:
v.in.dxf help
... there is no "category" but "lines" and "labels":
lines DXF layers with line data
labels DXF layers with label data
Markus
> ----- Original Message -----
> From: Miha STAUT <mihastaut at hotmail.com>
> To: <grasslist at baylor.edu>
> Sent: Thursday, October 10, 2002 11:24 AM
> Subject: [GRASSLIST:4699] RE: Categories in v.in.dxf
> > Hi, Antonio
> > Thanks for the tip, but are you completely sure that "v.in.dxf" has a
> > parameter like "category"? I looked in all the helps of Grass5.0.0. (if
> > there may be any difference) and they do not mention it. I also tried the
> > command with your suggestion on blind and it did not work. The program
> > outputs a message like "sorry, there is no parameter named category".
> > Miha Staut
> > >I think that there is an option "category=", isn't there? Try with
> > >category=Layer or category=Elevation.
> > >Antonio Uriarte.
