[GRASSLIST:4705] NVIZ startup crash
Rado Bonk
bonk at fns.uniba.sk
Fri Oct 11 10:18:28 EDT 2002
Hi GRASSusers,
I recently experienced a problem of NVIZ startup on computer equiped with
onboard graphic accelerator (SIS5513). NVIZ doesn't start at all
complaining about "bot enough memory". Attached is the NVIZ crash output
and dmesg graphic card related output during the boot process. I'm using
LRH7.3, and GRASS5.0.
Thanks for your help,
Rado
Radoslav Bonk M.S.
Comenius University, Faculty of Natural Sciences
Department of Physical Geography and Geoecology
Mlynska Dolina 842 15,Bratislava SLOVAKIA
fax:00421-2-654 29 064 phone: 00421-2-602 96 250
Linux version 2.4.18-3 (bhcompile at daffy.perf.redhat.com) (gcc version 2.96 20000731 (Red Hat Linux 7.3 2.96-110)) #1 Thu Apr 18 07:37:53 EDT 2002
BIOS-provided physical RAM map:
BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
BIOS-e820: 0000000000100000 - 0000000007800000 (usable)
BIOS-e820: 00000000ffef0000 - 00000000fff00000 (reserved)
BIOS-e820: 00000000ffff0000 - 0000000100000000 (reserved)
On node 0 totalpages: 30720
zone(0): 4096 pages.
zone(1): 26624 pages.
zone(2): 0 pages.
Kernel command line: ro root=/dev/hda1
Initializing CPU#0
Detected 434.317 MHz processor.
Console: colour VGA+ 80x25
Calibrating delay loop... 865.07 BogoMIPS
Memory: 118152k/122880k available (1119k kernel code, 4340k reserved, 775k data, 280k init, 0k highmem)
Dentry cache hash table entries: 16384 (order: 5, 131072 bytes)
Inode cache hash table entries: 8192 (order: 4, 65536 bytes)
Mount-cache hash table entries: 2048 (order: 2, 16384 bytes)
Buffer cache hash table entries: 4096 (order: 2, 16384 bytes)
Page-cache hash table entries: 32768 (order: 5, 131072 bytes)
CPU: Before vendor init, caps: 0183f9ff 00000000 00000000, vendor = 0
CPU: L1 I cache: 16K, L1 D cache: 16K
CPU: L2 cache: 128K
CPU: After vendor init, caps: 0183f9ff 00000000 00000000 00000000
Intel machine check architecture supported.
Intel machine check reporting enabled on CPU#0.
CPU: After generic, caps: 0183f9ff 00000000 00000000 00000000
CPU: Common caps: 0183f9ff 00000000 00000000 00000000
CPU: Intel Celeron (Mendocino) stepping 05
Enabling fast FPU save and restore... done.
Checking 'hlt' instruction... OK.
POSIX conformance testing by UNIFIX
mtrr: v1.40 (20010327) Richard Gooch (rgooch at atnf.csiro.au)
mtrr: detected mtrr type: Intel
PCI: PCI BIOS revision 2.10 entry at 0xfdb81, last bus=1
PCI: Using configuration type 1
PCI: Probing PCI hardware
PCI: Using IRQ router SIS [1039/0008] at 00:01.0
isapnp: Scanning for PnP cards...
isapnp: No Plug & Play device found
Linux NET4.0 for Linux 2.4
Based upon Swansea University Computer Society NET3.039
Initializing RT netlink socket
apm: BIOS version 1.2 Flags 0x03 (Driver version 1.16)
Starting kswapd
VFS: Diskquotas version dquot_6.5.0 initialized
pty: 2048 Unix98 ptys configured
Serial driver version 5.05c (2001-07-08) with MANY_PORTS MULTIPORT SHARE_IRQ SERIAL_PCI ISAPNP enabled
ttyS00 at 0x03f8 (irq = 4) is a 16550A
Real Time Clock Driver v1.10e
block: 224 slots per queue, batch=56
Uniform Multi-Platform E-IDE driver Revision: 6.31
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
SIS5513: IDE controller on PCI bus 00 dev 01
PCI: No IRQ known for interrupt pin A of device 00:00.1. Please try using pci=biosirq.
SIS5513: chipset revision 208
SIS5513: not 100% native mode: will probe irqs later
SiS620
ide0: BM-DMA at 0xffa0-0xffa7, BIOS settings: hda:pio, hdb:pio
ide1: BM-DMA at 0xffa8-0xffaf, BIOS settings: hdc:pio, hdd:pio
hda: WDC WD200AB-00BVA0, ATA DISK drive
hdb: ATAPI 52X CDROM, ATAPI CD/DVD-ROM drive
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
hda: 39102336 sectors (20020 MB) w/2048KiB Cache, CHS=2434/255/63, UDMA(66)
ide-floppy driver 0.99.newide
Partition check:
hda: hda1 hda2 hda3 hda4 < hda5 hda6 hda7 >
Floppy drive(s): fd0 is 1.44M
FDC 0 is a post-1991 82077
RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize
md: md driver 0.90.0 MAX_MD_DEVS=256, MD_SB_DISKS=27
md: Autodetecting RAID arrays.
md: autorun ...
md: ... autorun DONE.
NET4: Linux TCP/IP 1.0 for NET4.0
IP Protocols: ICMP, UDP, TCP, IGMP
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP: Hash tables configured (established 8192 bind 8192)
Linux IP multicast router 0.06 plus PIM-SM
NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
RAMDISK: Compressed image found at block 0
Freeing initrd memory: 123k freed
VFS: Mounted root (ext2 filesystem).
Journalled Block Device driver loaded
kjournald starting. Commit interval 5 seconds
EXT3-fs: mounted filesystem with ordered data mode.
Freeing unused kernel memory: 280k freed
Adding Swap: 514040k swap-space (priority -1)
usb.c: registered new driver usbdevfs
usb.c: registered new driver hub
usb-ohci.c: USB OHCI at membase 0xc8087000, IRQ 3
usb-ohci.c: usb-00:01.2, Silicon Integrated Systems [SiS] 7001
usb.c: new USB bus registered, assigned bus number 1
hub.c: USB hub found
hub.c: 2 ports detected
EXT3 FS 2.4-0.9.17, 10 Jan 2002 on ide0(3,1), internal journal
EXT3 FS 2.4-0.9.17, 10 Jan 2002 on ide0(3,7), internal journal
EXT3 FS 2.4-0.9.17, 10 Jan 2002 on ide0(3,5), internal journal
EXT3 FS 2.4-0.9.17, 10 Jan 2002 on ide0(3,2), internal journal
EXT3 FS 2.4-0.9.17, 10 Jan 2002 on ide0(3,3), internal journal
hdb: ATAPI 48X CD-ROM drive, 128kB Cache, UDMA(33)
Uniform CD-ROM driver Revision: 3.12
hdb: DMA disabled
PCI: Found IRQ 10 for device 00:09.0
3c59x: Donald Becker and others. www.scyld.com/network/vortex.html
00:09.0: 3Com PCI 3c905C Tornado at 0xde00. Vers LK1.1.16
dmfe: Davicom DM9xxx net driver, version 1.36.4 (2002-01-17)
PCI: Found IRQ 5 for device 00:10.0
eth1: Davicom DM9102 at pci00:10.0, 00:d0:09:04:1f:9a, irq 5.
eth1: Tx timeout - resetting
Linux agpgart interface v0.99 (c) Jeff Hartmann
agpgart: Maximum main memory to use for agp memory: 87M
agpgart: Detected SiS 620 chipset
agpgart: AGP aperture is 64M @ 0xe8000000
[drm] AGP 0.99 on SiS @ 0xe8000000 64MB
[drm] Initialized sis 1.0.0 20010503 on minor 0
cmpci: version $Revision: 5.64 $ time 07:42:57 Apr 18 2002
PCI: Found IRQ 9 for device 00:0f.0
cmpci: found CM8738 adapter at io 0xda00 irq 9
cmpci: chip version = 033
cmpci: Enable SPDIF loop
hdb: irq timeout: status=0xd0 { Busy }
hdb: ATAPI reset complete
The papers are available at
http://www2.gis.uiuc.edu:2280/modviz/
Loading Data
Loading Data
translating colors from fp
Adding panels from /usr/local/grass5/etc/nviz2.2/scripts
Nv_(panels)
toplevel made
SIS driver : out of video memory
Fatal errors in sis_dri.so
child process exited abnormally
while executing
"exec /usr/local/grass5/etc/nviz2.2/NVWISH2.2 -f /usr/local/grass5/etc/nviz2.2/scripts/nviz2.2_script elevation=DEM10 -name NVIZ >&@stdout"
("eval" body line 1)
invoked from within
"eval exec $env(GISBASE)/etc/nviz2.2/NVWISH2.2 -f $env(GISBASE)/etc/nviz2.2/scripts/nviz2.2_script $argv -name NVIZ >&@stdout"
invoked from within
"if {$argv == ""} {
#no arguments
eval exec $env(GISBASE)/etc/nviz2.2/NVWISH2.2 -f $env(GISBASE)/etc/nviz2.2/scripts/nviz2.2_script -name NVIZ >&@stdo..."
(file "/usr/local/grass5/bin/nviz" line 16)
