[GRASSLIST:4707] Re: NVIZ startup crash
Eric G. Miller
egm2 at jps.net
Fri Oct 11 11:17:54 EDT 2002
On Fri, Oct 11, 2002 at 04:18:28PM +0200, Rado Bonk wrote:
> Hi GRASSusers,
> I recently experienced a problem of NVIZ startup on computer equiped with
> onboard graphic accelerator (SIS5513). NVIZ doesn't start at all
> complaining about "bot enough memory". Attached is the NVIZ crash output
> and dmesg graphic card related output during the boot process. I'm using
> LRH7.3, and GRASS5.0.
Well, this is not a GRASS problem, per se. Adjusting your region
extents/resolution to a smaller area or lower resolution may help
reduce memory demand. From your message, it was the sis_dri.so driver
for X crapping out with a fatal error....
begin 664 .signature
M<F5L;&E-("Y'(&-I<D4@/G1E;BYS<&I`,FUG93P)"`@("`@("`@("`@("`@(
M"`@("`@("`@("`@("`@("`A%<FEC($<N($UI;&QE<B`\96=M,D!J<',N;F5T
"/@H`
end
