[GRASSLIST:4718] Re: Question about ps.map
Doug Gorley douggorley at shaw.ca
Sun Oct 13 15:48:28 EDT 2002
On Sun, 2002-10-13 at 00:59, Glynn Clements wrote:
> Doug Gorley wrote:
> > I have a question regarding ps.map.  I've created a ps.map input file
> > that looks like this:
> [snip]
> > This is working great, except for one thing: if I use d.zoom to display
> > a certain part of the map, that's the only part that'll show up in my
> > Postscript map.  Is this the intended behaviour,
> Yes.
> > or am I missing
> > something in the configuration?  Ideally, I thought the ps.map file
> > should be able to specify a center of the map, and the scale should be
> > independent on the d.mon display.
> It isn't just ps.map which is affected. Almost all GRASS commands
> operate upon the current region, and d.zoom changes the current
> region. d.zoom is effectively an interactive version of g.region.
> Glynn Clements <glynn.clements at virgin.net>
Thanks, that's a big help.  Is there any way I can specify the region I
want to map in the input file to ps.map, so that the script will
generate the same map every time?
Doug Gorley | douggorley at shaw.ca     OpenPGP Key ID: 0xA221559B
Fingerprint: D707 DB92 E64B 69DA B8C7  2F65 C5A9 5415 A221 559B
Interested in public-key cryptography?    http://www.gnupg.org/
