[GRASSLIST:4733] Re: what happened to i.grey.scale??
Glynn Clements
glynn.clements at virgin.net
Mon Oct 14 11:15:12 EDT 2002
francesco wrote:
> I just tried to do an histogram stretch with grass5 with the good old
> i.grey.scale command which I readily found in the GUI but when I run it,
> the binary file is not found... of course, because it was not there... I
> looked all over even at the precompiled grass5 binaries but no luck. So I
> had to fish it out from the grass4.3 version... anybody know why this
> is? Should I point this out to the grass coordinators or did I miss
> something (like a new module with a different name has replaced i.grey.scale)
i.grey.scale has been removed; equivalent functionality is provided by
"r.colors ... color=grey.eq". However, we need to fix tcltkgrass,
which still refers to i.grey.scale.
Glynn Clements <glynn.clements at virgin.net>
