[GRASSLIST:4743] Re: what happened to i.grey.scale??
    Markus Neteler
    neteler at itc.it
    Tue Oct 15 03:29:36 EDT 2002
On Mon, Oct 14, 2002 at 04:15:12PM +0100, Glynn Clements wrote:
> francesco wrote:
> > I just tried to do an histogram stretch with grass5 with the good old
> > i.grey.scale command which I readily found in the GUI but when I run it,
> > the binary file is not found... of course, because it was not there... I
> > looked all over even at the precompiled grass5 binaries but no luck.  So I
> > had to fish it out from the grass4.3  version... anybody know why this
> > is?  Should I point this out to the grass coordinators or did I miss
> > something (like a new module with a different name has replaced i.grey.scale)
> i.grey.scale has been removed; equivalent functionality is provided by
> "r.colors ... color=grey.eq". However, we need to fix tcltkgrass,
> which still refers to i.grey.scale.
Done.
 Markus
