[GRASSLIST:4732] Re: projection problem
Eric G. Miller
egm2 at jps.net
Mon Oct 14 11:46:52 EDT 2002
On Mon, Oct 14, 2002 at 05:24:30PM +0930, Martin Wegmann wrote:
> hello,
> I exported GRASS files from ERDAS imagine 8.5 as SUTM 52 (Australian
> National (ext. Spheroid) and AGD66 (ext. Datum)). In GRASS I created a
> mapset in UTM, Elipsoid Australian and the Datum AGD66, Zone 52, south
> and copied the files into this folder. When I run r.support on these
> images I get the error message: can't read the header file - invalid
> format - line 3:<north ......>
> I reprojected one image in ERDAS into WGS 84 (Spheroid and Datum) and
> exported that as GRASS file and it worked. But I would prefer not to
> reproject the other 100 images and instead find my mistake in GRASS.
> any idea what I did wrong?
What does <location>/<mapset>/cellhd/<raster> look like (it's just a
text file, but is the "header"). I'm presuming ERDAS only knows about
GRASS integer rasters (ver. 4.x)... Apparently, there's an error in
the header file...
static const char signature[] =
"Copyright (c) 2002 Eric G. Miller <egm2 at jps.net>";
