[GRASSLIST:4736] Re: r.in.gdal mystery
francesco
fpirotti at libero.it
Mon Oct 14 12:16:56 EDT 2002
At 08.48 14/10/02 -0700, you wrote:
>On Mon, Oct 14, 2002 at 04:44:11PM +0200, fpirotti at libero.it wrote:
> > Hello,
> > I compiled my grass5 and put in the libgdal.1.1.so library in the right
> > 'lib' folder, but the r.in.gdal module does not run... and it does not
> > even give me an error line in the GUI, and it gives me "segmentation
> > fault" when run in the command line.
> > Anybody have the same problem?
>Do you have the correct libstdc++ for libgdal? C++ libraries are very
>sensitive to this. Does "ldd libgdal1.1.so" find all it's dependencies?
>static const char signature[] =
> "Copyright (c) 2002 Eric G. Miller <egm2 at jps.net>";
Thank you for your answer Eric Miller!
yes, ldd libgdal.1.1.so finds all its links and the libstdc++... library is
the one I downloads from the package which included 2 files, that one and
libgdal , all compiled just for GRASS... as I said, it is a mystery.
Francesco
