[GRASSLIST:4741] Re: opengl compile problem
Richard Greenwood
Rich at GreenwoodMap.com
Mon Oct 14 19:33:46 EDT 2002
Many thanks to Glynn Clements, Eric Miller, and Scott O'Donnell for their
help!
Summary: GRASS 5.0.0 failed to 'configure' with Mesa 4.0.4 under Mandrake
9.0. The problem was that my libGLU somehow got built as a C++ library. The
solution, quoted from Glynn's email, is as follows:
>If you have autoconf installed, change line 850 of configure.in from:
>LOC_CHECK_LIBS(GLU,gluBeginCurve,GLU,$OPENGL_LIB_PATH,OPENGLULIB,$OPENGLLIB
>$X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB,,)
>to:
>$X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB,,,-lstdc++)
>(i.e. add ",-lstdc++ to the end of the list), then run "autoconf" in
>the top-level directory.
>Otherwise, you'll need to obtain the updated configure script from
>CVS:
>http://freegis.org/cgi-bin/viewcvs.cgi/*checkout*/grass/configure?rev=1.120
Thanks,
Rich
Richard W. Greenwood, PLS
Greenwood Mapping, Inc.
(307) 733-0203
http://www.GreenwoodMap.com
