[GRASSLIST:4744] Re: r.in.gdal mystery - Landsat
Markus Neteler
neteler at itc.it
Tue Oct 15 03:33:41 EDT 2002
On Mon, Oct 14, 2002 at 10:13:05AM -0700, Eric G. Miller wrote:
> On Mon, Oct 14, 2002 at 06:12:54PM +0200, andres javier garcia garcia wrote:
> > When I run r.in.gdal; and I'm not sure about the proper file to use as input
> > for Landsat7, because there are several files. I've tried to give to driver
> > everyone of the three administrative files, and I get:
> > ERROR 4: `L71199000_00020010726_HPN.FST' not recognised as a supported file
> > format.
> > ERROR 4: `L71199000_00020010726_HRF.FST' not recognised as a supported file
> > format.
> > ERROR 4: `L71199000_00020010726_HTM.FST' not recognised as a supported file
> > format.
> > So, I don't know what to do. Are these files the correct input?
> Which indicates r.in.gdal is working properly but doesn't recognize the
> file format. Do you know what the file format is? Perhaps changing the
> extension will help gdal pick the right translator...?
I think that it simply indicates that you GDAL is too old.
As far as I know the version containing LANDSAT-7 FAST support
is not yet released. You will have to compile from GDAL-CVS.
For me LANDSAT-7 import works well with above header files
(note this related bugreport. though:
http://bugzilla.remotesensing.org/show_bug.cgi?id=208
Cheers
Markus
