[GRASSLIST:4745] Re: r.in.gdal mystery - Landsat
Andrey Kiselev dron at at1895.spb.edu
Tue Oct 15 04:38:05 EDT 2002
Hi, Javier,
On Mon, Oct 14, 2002 at 06:12:54PM +0200, andres javier garcia garcia wrote:
> I've imported tiff, gif, jpg and png previously; with different results but
> correctly. the Landsat images are FST files.
You need GDAL library from the CVS for Landsat. Landsat importing was
not supported in the GDAL 1.1.7.
> When I run r.in.gdal; and I'm not sure about the proper file to use as input
> for Landsat7, because there are several files. I've tried to give to driver
> everyone of the three administrative files, and I get:
> ERROR 4: `L71199000_00020010726_HPN.FST' not recognised as a supported file
> format.
> ERROR 4: `L71199000_00020010726_HRF.FST' not recognised as a supported file
> format.
> ERROR 4: `L71199000_00020010726_HTM.FST' not recognised as a supported file
> format.
> So, I don't know what to do. Are these files the correct input?
Yes, you have used right files for input. But you should build latest GDAL
from the sources first.
Andrey V. Kiselev
Scientific Research Center for Ecological Safety Russian Academy of Sciences
Office phone:  +7 812 2307834  ICQ UIN 26871517
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20021015/b305cfbd/attachment.bin
