[GRASSLIST:4751] Re: batch jobs
Kevin Slover Kevin.Slover at noaa.gov
Tue Oct 15 22:59:04 EDT 2002
Martin,
	I have done several batch programs to help with the input of data into
GRASS.  The writing of these scripts is not overly difficult, but it can
get confusing at times.  I would be happy to send you a snip-it of my
script to help you get started with it.
	Earlier, I had to import up to 200 xyz files and create rasters out of
them, and wrote a script that would read a directory, and perform
s.in.ascii and s.surf.idw.  It worked without a hitch.  I will send it
tomorrow morning if you would like, when I get back into work.
Martin Wegmann wrote:
> hello,
> I have a couple of commands which I have to run on each image. Would it be possible to merge these commands and only change the input and output each time for each image?
> like input=map1 output=map1a
> command x  in=map1 out=x
> command y  in=x out=y
> and so on until the final out=map1a
> as far as I understood the use of shell scripts, they are desigend to do this. But how do I write them and load them into GRASS?
> thanks for your help,
> Martin
> Martin Wegmann
> Tropical Ecosystem Research Center
> PMB 44 Winnellie / Darwin
> NT 0821
> Australia
> priv.
> 4 Carpentier Cres.
> Wagaman / Darwin
> NT 0810
> Autralia
> 0061 8 8927 1241
LTJG Kevin Slover, NOAA
GIS Specialist/Oceanographer/Meteorologist
Tropical Prediction Center/Technical Support Branch
11691 SW 17th St Miami FL  33165
W- 305-229-4456
