[GRASSLIST:4753] RE: batch jobs
Antonio Uriarte antoniouriarte at terra.es
Wed Oct 16 16:25:04 EDT 2002
I think you can follow the next process:
- Create the script for one image.
- Open the script in a text editor (for example, Microsoft Word).
- Use a macro to duplicate the instructions of the scripts as many times as
images you have, changing the name of the image in the input and the output.
- Run this new script in GRASS.
I hope it will work.
----- Original Message -----
To: GRASSLIST (eng.) <GRASSLIST at baylor.edu>
Sent: Wednesday, October 16, 2002 3:57 AM
Subject: [GRASSLIST:4750] batch jobs
> hello,
> I have a couple of commands which I have to run on each image. Would it be
possible to merge these commands and only change the input and output each
time for each image?
> like input=map1 output=map1a
> command x  in=map1 out=x
> command y  in=x out=y
> and so on until the final out=map1a
> as far as I understood the use of shell scripts, they are desigend to do
this. But how do I write them and load them into GRASS?
> thanks for your help,
> Martin
> Martin Wegmann
> Tropical Ecosystem Research Center
> PMB 44 Winnellie / Darwin
> NT 0821
> Australia
> priv.
> 4 Carpentier Cres.
> Wagaman / Darwin
> NT 0810
> Autralia
> 0061 8 8927 1241
