[GRASSLIST:4755] Re: batch jobs
Christoph Hoegl
C.Hoegl at gmx.net
Wed Oct 16 18:16:28 EDT 2002
m.wegmann at web.de said:
> hello,
> I have a couple of commands which I have to run on each image. Would
> it be possible to merge these commands and only change the input and
> output each time for each image?
> like input=map1 output=map1a
> command x in=map1 out=x command y in=x out=y and so on until the
> final out=map1a
> as far as I understood the use of shell scripts, they are desigend to
> do this. But how do I write them and load them into GRASS?
> thanks for your help, Martin
What about this approach:
write all your actions in a loop like this (this expects you're using bash
(standard shell on Linux)
for i in all_filenames_go_here ; do
x in=$i out=$i.x.out
y in=$i.x.out out=$i.y.out
done
you may also like to do some renaming on the way:
e.g. there are some files named *.bla to be processed by the tools x and y
for i in *.bla ; do
$basename=${i%.bla}
x in=$i out=$basename.suffix
y in=$basename.suffix out=$basename.sfx2
done
kind regards,
Christoph
