[GRASSLIST:4752] grasslist@baylor.edu
Tom Z. Meinlschmidt tm at salome.datron.cz
Wed Oct 16 08:47:42 EDT 2002
i've following problem. I'm a beginner in Grass, but he seems to be the right
I was finding ever :)
I've elevation data in xyz site. So I need to interpolate and create raster from it,
but there's the problem.
With s.surf.rst I'm using default values - it works good but for  'higher' elevations only,
not for plains and valleys.. I need to do the following:
make s.surf.rst with tension and smooth values equals to something, if elevation > something,
and the same with another values for lower elevations...
(similarity to Surfer: for highers use Kriging method, for lower use triangulation...)
could you help me, please?
thank you
Tom
Tomas Meinlschmidt, SBN3, MCT, MCP, MCP+I, MCSE, NetApp Filer & NetCache
Datron s.r.o., Vachkova 3008, 470 01 Ceska Lipa, 487 834 421, f: 487 834 425
GCS d-(?) s: a- C++ ULHISC*++++$ P+++>++++ L+++$>++++ E--- W+++$ N++(+) !o
    !K w(---) !O !M V PS+ PE Y+ PGP++ t+@ !5 X? R tv b+ !DI D+ G e>+++
    h---- r+++ z+++@
