[GRASSLIST:4756] i.rectify doesn't produce an correct output
Rado Bonk bonk at fns.uniba.sk
Thu Oct 17 09:26:39 EDT 2002
Hello GRASSusers,
I came into the problems using i.rectify command. My area of interest (AOI) is
200mx3000m (res=1m, projection -x,-y), however this belt is start at SE
and ends at NW corner of the region. Thus there are a lots of NULL
cells outside the AOI. To decrease the amount of NULL
cells (for using the AOI in R language) I want to rectify (rotate) the
belt into a horizontal position using lower right corner as a point of
rotation. The target location is x,y, res=1m.
i.rectify finish the job without sending an email to localhost, and:
1. there is a output raster in cell directory with zero filesize
2. output file is missing in cellhd directory
3. output file is missing in cell_misc directory
4. output file is missing in cats directory
5. output file has non zero filesize in fcell directory but r.support,
and r.mapcalc don't work on it.
Is the -x,-y at original LOCATION, or reasonable fine resolution a problem? Is there a
way in GRASS to rotatea region by an arbitrary angle (I can imagine that
using r.proj magic)
Thanks,
Rado
 Radoslav Bonk M.S.
 Comenius University, Faculty of Natural Sciences
 Department of Physical Geography and Geoecology
 Mlynska Dolina 842 15,Bratislava SLOVAKIA
 fax:00421-2-654 29 064 phone: 00421-2-602 96 250
