[GRASSLIST:4780] Re: error when starting grass5 - corrected
    Holger Zebner
    holgerzebner at gmx.de
    Fri Oct 18 14:23:49 EDT 2002
I have checked my current setup for libtermcap but it couldn't be located.
Where (in my filesys) should it be? From where could I get it if SuSe
doesn't have it?
Thanks
Holger
At 00:51 18.10.02 +0100, you wrote:
>Holger Zebner wrote:
> > I need help on starting my new installed GRASS 5.0 (on SuSE 7.1).
> > After I have typed the "grass5" command I get the info (Welcome to
> > blabla...) msg and then I press return. After that I get the error msg
> > "/usr/local/grass5/etc/set_data: error while loading shared libaries:
> > libtermcap.so.2: cannot open shared object file: No such file or directory"
> > What can I do?
>Check whether SuSE provides a "libtermcap" package.
>Glynn Clements <glynn.clements at virgin.net>
