[GRASSLIST:4835] Re: grass file?
Kevin Slover Kevin.Slover at noaa.gov
Fri Oct 25 11:15:26 EDT 2002
Jeff,
	I have done this several times.  Depending on your project size, you
might want to just transfer your entire directory (location).  This for
me has worked with backups of data sets.  Other than that, my guess (and
people will tell me I am wrong, I am sure) but you need the support
files, PROJ_INFO, PROJ_UNITS, WIND, as well as the support files for
each file, under cats, cell, cellhd, etc for a raster and dig_* for
vector.  I just find it easier to tar the directory, and then move it,
keeps all the files together that you need.
"Jeff D. Hamann" wrote:
> I've got a couple of computers that I have grass projects on and I would
> like to be able to transfer a grass "file" from one machine to another
> without exporting the fle to an ascii file (or something equivalent). Is
> there a native grass file format that can be simply copied from one machine
> to another?
> Jeff
> Jeff D. Hamann
> Hamann, Donald & Associates, Inc.
> PO Box 1421
> Corvallis, Oregon USA 97339-1421
> Bus. 541-753-7333
> Cell. 541-740-5988
> jeff_hamann at hamanndonald.com
> www.hamanndonald.com
LTJG Kevin Slover, NOAA
GIS Specialist/Oceanographer
NOAA/TPC/TSB/Storm Surge Unit
11691 SW 17th Street
Miami FL  33165
W (305) 229-4456
