[GRASSLIST:4846] odbc problem
    Miha STAUT
    mihastaut at hotmail.com
    Sun Oct 27 11:11:15 EST 2002
Hi everybody,
Thanks for replying me so numerously. When I executed the "g.select.pg
database=database_name", I got the following message:
GRASS:~ > g.select.pg database=obc
g.select.pg: error while loading shared libraries: libpq.so: cannot open
shared object file: No such file or directory
Even though I checked everywhere, I could not find the missing library on my
computer. The description of the package postgresql-libs-7.2.1-5.i386.rpm
states that it has it. ???
I found other libraries depending to the package in the standard location
(/usr/lib). I solved the problem with duplicating libpq.so.2 and renaming it
to libpq.so. It worked.
Miha Staut
_________________________________________________________________
Surf the Web without missing calls! Get MSN Broadband.
http://resourcecenter.msn.com/access/plans/freeactivation.asp
