[GRASSLIST:4495] Re: aggregate a higher resolution to a lower resolution
Glynn Clements glynn.clements at virgin.net
Fri Sep 13 11:00:49 EDT 2002
Ulrich Leopold wrote:
> I would like to aggregate my map from a 250x250m resolution to a 500x500m
> resolution. If I use resample the nearest neighbor is used. Is there a
> possibility to just average 4 250x250m blocks (like overlay a grid and
> average) instead of nearest neigbor? So that I derive a mean and a variance?
Apart from r.resample, there's also r.resamp.rst, which does spline
interpolation. However, I'm not aware of anything which resamples
using a simple average.
Glynn Clements <glynn.clements at virgin.net>
