[GRASSLIST:4551] Averaging Images - easier way?
Daniel Victoria
daniel_victoria at yahoo.com
Fri Sep 20 15:26:05 EDT 2002
Hi all,
I need to do an image averaging and I found this on
the list archives:
> I have some problems with r.mapcalc: I have imported
several images with
> r.in.bin. The data are 2 byte ints - everything went
fine. I want to
> calculate an average image by using r.mapcalc. It is
not as simple as it
> sounds first, since there are some gaps in the data
(every day has an
> image, but not all pixels in the images are "not
zero", and the "non
> zero" cells are not at constant places). So I
thought to set up a
> routine that
> - adds all images together, resulting in an image
"sum"
> (r.mapcalc sum=day1+day2+day3+...)
> - creates an image of a sum of all "if(image)"
resulting in "count"
> (r.mapcalc count=if(day1)+if(day2)+if(day3)+...)
> - calculate the avarege by division "sum/count"
> (r.mapcalc average=sum/count)
Is there an easier way to do it in just one simple
command or is that the only way? Also, if this is the
only way, could someone suggest a script?
Thanks
Daniel
__________________________________________________
Do you Yahoo!?
New DSL Internet Access from SBC & Yahoo!
http://sbc.yahoo.com
