[GRASSLIST:5963] Re: openosx 5.0.1 update breaks grass?
Glynn Clements
glynn.clements at virgin.net
Fri Apr 4 04:09:39 EST 2003
Mike S wrote:
> I've got an odd problem I havent tried to trouble shoot myself yet (I'm
> not a unix guru). I'm running OS X 10.2.4, Apples x11 beta 3, and
> openosx.com grass 5.0.0 package. I installed the updater that they had
> posted under the support part of their site, which effectively updates
> it to 5.0.1. Well now when I try to boot grass...
> Starting GRASS ...
> Error in startup script: can't read "env_location": no such variable
> while executing
> "set location $env_location"
> (procedure "searchGISRC" line 23)
> invoked from within
> "searchGISRC $gisrc_name"
> (file "/usr/local/grass5/tcltkgrass/script/gis_set.tcl" line 1)
> ERROR: LOCATION_NAME not set
> /usr/local/grass5/etc/Init.sh: GISDBASE: parameter null or not set
> I don't get anywhere. I just returns me at the shell prompt. Now I have
> some clue what might be happening. But that clue wont go anywhere
> because it is nearly 2 am.
> Any ideas on how to fix this?
Delete the ~/.grassrc5 file and try again.
Glynn Clements <glynn.clements at virgin.net>
