[GRASSLIST:5990] Re: problem with r.in.ascii
    Schuyler Fishman
    schuylerfish at earthlink.net
    Wed Apr  9 13:11:42 EDT 2003
Thanks for your reply, I really appreciate the help everyone has given
me on this list.
The problem seems to be that when I run s.to.rast, I am unsure of what
options to
choose, and when I run it with default, I get a segmentation error.
Options - questions
input= site file
output= rater file
size= value
Number of cells to surround site cell
If my model output is a 20m grid and my location resolution is 1m
should this size be 20?
title= obvious
field= value
Attribute field type to use for operation
options: dim,decimal,cat
default: decimal
I am not sure what to use here, because I imported a floating point
value and when I do d.info for sites it appears there are two
categories - the second one is the value I need.
findex= value
Attribute field number to use for operation
default: 1
So should this be 1 or 2?
string= value
String attribute number to use for description
default: 1
Is this the difference between cat and cat description? I am confused.
Results of s.info
SITES FILENAME: Brite.89s at PERMANENT
Header Information:
         name          Brite.89s
         description   s.in.ascii sites=Brite.89s input=Brite.89s
fs=space
Number of DIMENSIONS:         2
                  - - MIN - -     - - MAX - -
         dim  1  566376.000000   567356.000000   Easting
         dim  2  4179541.000000  4180521.000000  Northing
Type of CATEGORY information: CELL_TYPE
                            1            2500
Number of DOUBLE attributes:  1
                  - - MIN - -     - - Q1 - -      - - MED - -     - - Q3
         dbl  1             0        0.101395        0.172225
0.325565
      36.1833
Number of STRING attributes:  0
TOTAL SITES COUNTED: 2500
Results of d.s.info
566512.8(E) 4180380(N)
Brite.89s in PERMANENT  566516|4180381 2108  0.0808
566858.2(E) 4180100.6(N)
Brite.89s in PERMANENT  566856|4180101 1425  2.34583
It is the second column that I want.
Thanks in advance for your help
On Wednesday, April 9, 2003, at 03:47  AM, H Bowman wrote:
> Problem is, r.in.ascii doesn't take x,y,z as input. It takes blocks of
> numbers.
> For x,y,z data, use s.in.ascii and s.to.rast and see how it goes.
> Alternatively, get good with Matlab/Octave and convert in into the form
> r.in.ascii does like:
> EXAMPLE (from the man page)
> The following is a sample input file to r.in.ascii:
> north: 4299000.00
> south: 4247000.00
> east: 528000.00
> west: 500000.00
> rows: 10
> cols: 15
> null: -9999
> 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
>> Ok - now I revise my question, the output is x,y,z and the grid
>> spacing (20x20m) is of lower resolution than the location (1x1m).
>> How do I create a raster layer from this data? Does anyone have
>> any quick suggestions or scripts to get the data into the right
>> format?
>> The grid is 500 rows x 500 columbs
>> Here is a sample header from the file
>> south: 4179541
>> east: 567376
>> west: 566376
>> rows: 2500
>> cols: 3
>> 566376.00000 4179541.00000 0.02640
>> 566396.00000 4179541.00000 0.02788
>> 566416.00000 4179541.00000 0.02962
Schuyler Fishman
Schuylerfish at earthlink.net
www.mindlikesky.com
Name: not available
Type: text/enriched
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20030409/e1e2b2b1/attachment.bin
