[GRASSLIST:5986] v.support after dxf-import
Heiko.Kehlenbrink at vermes.fh-oldenburg.de Heiko.Kehlenbrink at vermes.fh-oldenburg.de
Wed Apr 9 08:24:41 EDT 2003
hi all,
got some probs running v.support on a vectorfile i imported with v.in.dxf.
first to say the dxf was konverted from a dwg via dwg2dxf ...
the import into grass worked quite fine and i could see all layers.
but when i tried to d.what.vect a vectormap i was recommended to run v.support.
doing so i recieved following statements:
GRASS:~/bin > v.support flowlines.B-WALL
V.SUPPORT:
Selected information from vector header
 Organization:  GRASS Development Team
 Map Name:      /home/hkehlenbrink/data/
 Source Date:
 Orig. Scale:   2400
 Snapping threshold    0.00
Snapp No snapping will be done
    Reading Vector file 100%
    Building areas 100%
    Building islands (no islands present)
    Attaching labels
Bad line 'L  760018.067072 3331154.451845 BUND WALL
Bad line 'L  762849.294835 3332406.368217 BUND WALL
Bad line 'L  763265.892428 3332517.292070 TRENCH
Bad line 'L  762132.304885 3331594.818630 TRENCH
Bad line 'L  761732.112157 3331353.784390 BUND WALL
Bad line 'L  769119.536408 3328353.856146 BUND WALL
Bad line 'L  768960.421895 3328594.632634 TRENCH
Bad line 'L  766081.951591 3331342.621904 TRENCH
 Number of lines:   20
 Number of nodes:   27
 Number of areas:   0
 Number of isles:   0
 Number of atts :   0
 Number of unattached atts :   0
 Snapped lines  :   0
the former dig_att was :
after v.support the dig_att was empty.
any help very welcome
best regards
heiko kehlenbrink
