[GRASSLIST:5992] Re: v.support after dxf-import
Paul Kelly
paul-grass at stjohnspoint.co.uk
Wed Apr 9 14:12:28 EDT 2003
On Wed, 9 Apr 2003 Heiko.Kehlenbrink at vermes.fh-oldenburg.de wrote:
> hi all,
> got some probs running v.support on a vectorfile i imported with v.in.dxf.
> after v.support the dig_att was empty.
Try the solution here and see if it works:
http://op.gfz-potsdam.de/GRASS-List/Archive/msg08556.html
Let us know if it does; maybe v.in.dxf needs to be fixed.
(You can probably ignore the references to v.in.dxf3d but you will need to
run v.in.dxf again and run the script before doing v.support. And there
might still be other problems.)
Paul
