[GRASSLIST:5995] Re: Postgress and GRASS CD
david mahoney
mahoneyd at unbc.ca
Wed Apr 9 18:27:42 EDT 2003
You need a postgres user and a postgres group on your system. For some
reason the MySQL install (via Fink) creates the necessary user and
group for itself, but Postgres doesn't.
If you have Mac OS X 10.2 or later, you can just add a line to your
/etc/group file.
postgres:*:71:
The group number 71 works on my system, but if there's already a 71 in
the group file, choose an unused number.
To add the user postgres, run sudo vipw. You get to edit the passwd
file with vi.
Add something like
postgres:*:71:71:Postgresql Server:/nohome:/noshell
Again, if 71 is taken, use something else.
If you can't figure out vi, or don't have Jaguar, you're stuck with
adding the user and group in NetInfo (/Applications/Utilities/NetInfo
Manager)
Good Luck
Dave
On Tuesday, April 8, 2003, at 04:01 PM, John Chesnut wrote:
> Can some one who has experience getting Postgres interoperating with
> Grass on Mac OSX please post step by step instructions.
> The initdb command will create a "data" directory, but the postgres
> server fails on startup. The initdb command requires su as the
> "postgres" user
> su postgres
> /usr/local/pgsql/bin/initdb -D /usr/local/pgsql/data
> complete successfully.
> Several issues are apparent
> 1. Postmaster does not successufully start using the terminal command
> postmaster (eg.
> sudo -u postgres /usr/local/pgsql/bin/postmaster -i -D
> this reports the error
> FATAL: no such group 'pgsql'
> /usr/local/pgsql/bin/postmaster: cannot create UNIX stream port
> my interpretation: some parts of postmaster need write permission
> with group pgsql which is not created by MacOSX
> 2, attempting to open the postmaster with the command
> sudo -u pgsql /usr/local/pgsql/bin/postmaster -i -D
> yield the error
> FATAL 1: cannot open /usr/local/pgsql/data/PG_VERSION: Permission
> denied
> my interpretation: requires read permission of user "postgres" which
> is lacking for user pgsql
> (I created the alternative user pgsql in an attempt to start
> postmaster)
> 3. attempting to start postmaster using the pg_ctl script as either
> user postgres or pgsql yields a similar error.
> sudo -u root sudo -u pgsql /usr/local/pgsql/bin/pg_ctl start -D
> this returns a message
> postmaster successfully started
> denied
> same error as 2.
> Evidently getting the postmaster/postgres server running need
> alterations of permissions and groups, but no documentation is
> available that explains how to create a "pgsql" group and associate it
> with a "postgres" user.
> Changing the /usr/local/pgsql/data directory permissions to 777 or 766
> yields an fatal error that permissions are incorrect: so simply
> expanding permissions doesn't work. The error reported is:
> FATAL 1: data directory /usr/local/pgsql/data has group or world
> access; permissions should be u=rwx (0700)
> trying to create a user from within postgres as in
> sudo -u postgres /usr/local/pgsql/bin/createuser jchesnut
> fails because
> psql: could not connect to server: No such file or directory
> Is the server running locally and accepting
> connections on Unix domain socket "/tmp/.s.PGSQL.5432"?
> my interpretation: postmaster / postgres must be running before the
> createuser command can be issued. postgres wont run because of the
> fatal errors listed above.
> Please help, if you know how to get postgres running under OSX
