[GRASSLIST:6026] Re: [Q] Long path for DATABASE
Shin, Daehyok
sdhyok at cardopia.co.kr
Fri Apr 11 14:20:42 EDT 2003
In my opinion, the length of 50 characters are too restrictive,
considering most configurations of file system in modern machines.
No possibility to relieve the restriction?
Daehyok Shin (Peter)
-----Original Message-----
From: owner-GRASSLIST at baylor.edu [mailto:owner-GRASSLIST at baylor.edu]On
Behalf Of Glynn Clements
Sent: Friday, April 11, 2003 AM 11:21
To: Shin, Daehyok
Cc: GRASSLIST at baylor.edu
Subject: [GRASSLIST:6022] Re: [Q] Long path for DATABASE
Shin, Daehyok wrote:
> Maybe a trivial question, but I can't find the answer
> from the web site.
> How can I put in a very long path to DATABASE
> in the first setup window of GRASS?
You can't; the interactive startup imposes a 50-character limit upon
the database directory.
However, you can avoid that limit by using the non-interactive
startup, i.e.
grass5 /path/to/database/location/mapset
Glynn Clements <glynn.clements at virgin.net>
