[GRASSLIST:6083] Re: Getting started with postgresql and GRASS
Glynn Clements glynn.clements at virgin.net
Thu Apr 17 20:40:51 EDT 2003
Michael Ash wrote:
> GRASS:~ > g.select.pg -l
> g.select.pg: error while loading shared libraries: libpq.so: cannot load shared object file: No such file or directory
> GRASS:~ > locate libpq.so
> /usr/local/pgsql/lib/libpq.so.3
> /usr/local/pgsql/lib/libpq.so.3.0
If you put shared libraries in a non-standard location (i.e. anywhere
other than /lib and /usr/lib), you have to tell the loader. E.g.:
	LD_LIBRARY_PATH=/usr/local/pgsql/lib
	export LD_LIBRARY_PATH
Or, if LD_LIBRAY_PATH is already defined:
	LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/pgsql/lib
Or add /usr/local/pgsql/lib to /etc/ld.so.conf then run "ldconfig".
The ld.so(8) man page might have useful information (or it might just
be hopelessly out of date; any references to a.out are ancient
history).
Glynn Clements <glynn.clements at virgin.net>
