[GRASSLIST:6099] Re: Compiling GRASS on Mac OS 10.2: CREATE_GMAKE.sh not found
Glynn Clements
glynn.clements at virgin.net
Sat Apr 19 09:08:42 EDT 2003
Anton Pitts wrote:
> The only warning in configure's output was: configure: warning: ***
> Unable to locate iconv() function.
That's harmless
> And indeed said file and directory do not exist:
> [Chiclet:~/Desktop/grass-5.0.1_src/grass5.0.1] anton% ls src/cmd/*
> src/cmd/head:
> head.powerpc-apple-darwin6.5
> src/cmd/lists:
> optional
> src/cmd/next_step:
The directory is supposed to be called "src/CMD", not "src/cmd".
It looks as if the source package wasn't unpacked correctly. Did you
use "tar" from the command line, or did you use some other tool?
Glynn Clements <glynn.clements at virgin.net>
