[GRASSLIST:6133] Re: nviz startup script error
    Glynn Clements
    glynn.clements at virgin.net
    Thu Apr 24 13:19:12 EDT 2003
javier garcia wrote:
> I've recently installed grass5.0.2. And I've tried to execute nviz with the
> following result:
> Error in startup script: Togl: X server has no OpenGL GLX extension
Your OpenGL library isn't compatible with your X server.
Basically, you have a "real" OpenGL library, which expects the X
server to do the actual OpenGL rendering (unlike Mesa, which does the
rendering itself).
If you're using XFree86 4.x, you need to have:
    Load	"glx"
in the "Module" section of the XF86Config file.
You can use the "glxinfo" utility to check whether your X server is
set up correctly.
Alternatively, you could use Mesa, which does the rendering itself,
and sends the rendered image to the X server (consequently, it doesn't
need GLX support in the X server).
> I couldn't install readline (could this have any relationship?)
No. The readline library is optional, and is only used by r.mapcalc.
Glynn Clements <glynn.clements at virgin.net>
