[GRASSLIST:6144] using Linux 9/GRASS 5.0 having problem with -tcltk option
    Greg Sepesi
    sepesi at eduneer.com
    Sun Apr 27 12:46:51 EDT 2003
Greetings,
When I attempt to run
	$ grass5 -tcltk
the response is
	WARNING: The wish command (/home/gjs/ActiveTcl/bin/wish) was not found!
	Please check your GRASS_WISH environment variable.
When I check the GRASS_WISH environment variable with
	GRASS: ~> g.gisenv GRASS_WISH
the response is
which seems okay.  Furthermore when I copy and execute that string at a
bash prompt, the wish widget appears.
I'm a new GRASS user and am hoping to soon be a source contributor.  Any
suggestions on how I should get the -tcltk option working?  It appears
to me that the wish and tclsh binaries are installed correctly and the
GRASS_WISH and GRASS_TCLSH environment variables are defined correctly.
Maybe the "Please check your GRASS_WISH environment variable" suggestion
is a red herring?
Regards,
Greg
