[GRASSLIST:6145] Re: using Linux 9/GRASS 5.0 having problem with -tcltk option
Glynn Clements
glynn.clements at virgin.net
Sun Apr 27 16:30:47 EDT 2003
Greg Sepesi wrote:
> When I attempt to run
> $ grass5 -tcltk
> the response is
> WARNING: The wish command (/home/gjs/ActiveTcl/bin/wish) was not found!
> Please check your GRASS_WISH environment variable.
> When I check the GRASS_WISH environment variable with
> GRASS: ~> g.gisenv GRASS_WISH
Note: GRASS_WISH is an actual environment variable, not a GRASS
variable (unfortunately, some of the GRASS documentation confuses the
two).
> the response is
> which seems okay. Furthermore when I copy and execute that string at a
> bash prompt, the wish widget appears.
> I'm a new GRASS user and am hoping to soon be a source contributor. Any
> suggestions on how I should get the -tcltk option working? It appears
> to me that the wish and tclsh binaries are installed correctly and the
> GRASS_WISH and GRASS_TCLSH environment variables are defined correctly.
> Maybe the "Please check your GRASS_WISH environment variable" suggestion
> is a red herring?
GRASS_WISH is treated as the base name of the wish program (e.g.
"wish" or "wish8.3"); the startup script looks for that file in each
directory in your current path.
Adding /home/gjs/ActiveTcl/bin to PATH and undefining GRASS_WISH (or
setting it to "wish") should work.
It should probably be changed to allow GRASS_WISH to be a full
pathname.
Glynn Clements <glynn.clements at virgin.net>
