[GRASSLIST:880] Re: r.terraflow compile error
Jaro Hofierka hofierka at geomodel.sk
Fri Aug 1 02:56:13 EDT 2003
Ian,
I have successfully compiled r.terraflow several times on Mandrake. If
you need a binary I can send it. Just let me know off the list.
If you need to compile the module then make sure that you have installed
all red hat packages (rpms) needed by r.terraflow. The error message
below doesn't say too much so I can't figure out the problem.
Jaro
Ian Allan wrote:
> Dear List
> We're still can't compile r.terraflow. Below is a summary of our
> compile. Any ideas anybody?
> Many thanks
> Ian Allan
> # How-to make Grass 5.0.2
> # /usr/local/grass5.0.2/src.contrib/DUKE
> cd /usr/local/grass5.0.2
> ./configure --without-odbc --without-postgres --without-fftw --with-cxx
> make pre-compile
> make 2>&1 | tee make.log
> cd /usr/local/grass5.0.2/src.contrib/DUKE/r.terraflow
> gmake5 -i
> # fails with:
> #  g++ -c -I/usr/local/grass5.0.2/src/include -g -O2 -Wall
> #  -I./IOStream/include -DUSER=\"root\" -DNODATA_FIX
> -D_FILE_OFFSET_BITS=64
> #  -DELEV_FLOAT main.cc -o OBJ.i686-pc-linux-gnu/FLOAT/main.o
