[GRASSLIST:889] Re: Contracted Grass support?
Sun Aug 3 00:19:49 EDT 2003
> > I've been told that I have to use "ArcInfo" software to produce 'eye
> > candy' maps, however I'm determined to use Grass, even it requires
> > purchasing custom
> > development.
> If your goal is good looking maps,
> many cartographers prefer to do the map development and analysis
> with GRASS and produce vector output formats which are then
> processed with more general Free Software graphic applications.
For what it's worth, I think ps.map does a pretty good job of making
good looking, precisely laid out hard copies, especially if you want to
create a template to create many maps of the same region.
Granted it takes some learning, isn't the prettiest of interfaces, and I
had to edit some of the source code to get it to look exactly the way I
wanted it to, but with a little work I am very happy with the results.
While other software such as GMT may still do a better job, it is
possible to make ps.map produce nice output.
Hamish
