[GRASSLIST:900] Re: displaying two adjacent raster maps
    Glynn Clements
    glynn.clements at virgin.net
    Mon Aug  4 07:08:53 EDT 2003
wouter buytaert wrote:
> Having two adjacent aerial photographs imported in grass, it's quite
> annoying that I can't display them both, because when displaying a
> photograph, al space around it is filled with white, covering the other
> photo. Is there a way to make the white transparant, or to cut only the
> photo part out of the apparently larger map?
> (grass 5.0.2)
What are you using to display the maps? Both d.rast an d.rgb have a
flag (-o) to disable filling of null cells.
Glynn Clements <glynn.clements at virgin.net>
