[GRASSLIST:956] Re: unable to locate postgresql includeds
stef sepd2003 at yahoo.com
Thu Aug 14 23:24:31 EDT 2003
Hello,
Well after a day trying different approaches I
continue to be lost.
I cannot seem to hold the ./configure
--with-Postgres-includes=/usr/local/postgresql-7.3.4/src/included
After the configuration runs it still cannot see the
libpq-fe.h file (yes, it is there) and in the line
above does not indicate that the path was changed.
Any suggestions?
Thanks,
Stef
--- Glynn Clements <glynn.clements at virgin.net> wrote:
> stef wrote:
> > I read the june 2002 reply to Mr. Bonk from Mr.
> > Clements and still have had no luck with this
> problem
> > of finding the header files for libpq-fe.
> > I have checked the config log but I have no
> clue..I
> > just see several files missing.  I have attached
> the
> > portion of the log for any insight and
> suggestion/s
> > you may have.
> > configure:8902: checking for location of
> PostgreSQL includes
> > configure:8928: checking for libpq-fe.h
> > configure:8936: gcc -E   conftest.c >/dev/null
> 2>conftest.out
> > configure:8932:22: libpq-fe.h: No such file or
> directory
> I note that there are no -I switches in the command,
> which means that
> you didn't use --with-postgres-includes=.... You
> almost always need to
> use this switch, as distribution vendors usually put
> the PostgreSQL
> headers in their own directory. Likely candidates
> are
> /usr/include/psql, /usr/include/pgsql and
> /usr/include/postgresql.
__________________________________
Do you Yahoo!?
Yahoo! SiteBuilder - Free, easy-to-use web site design software
http://sitebuilder.yahoo.com
