[GRASSLIST:980] g.select.pg problem: list OK but refuse to select available database
    tlaronde at polynum.org
    Thu Aug 21 03:50:18 EDT 2003
Hello,
I'm using grass 5.0.2 and PostgreSQL 7.3.4.
Postmaster is running OK, and can do management with
psql.
When running g.select.pg, the connection is OK when asked
do list the available databases, but when selecting one
it says that the connexion was refused.
Is g.select.pg using "native" Postgres access or is it using
unixODBC? Has somebody any clue?
By the way, db.databases is core dumping so the connection
via unixODBC is ready at hand, and I don't know exactly
where to start looking for the source of the problem.
Thanks in advance.
