[GRASSLIST:988] Re:
    Glynn Clements
    glynn.clements at virgin.net
    Thu Aug 21 07:24:04 EDT 2003
Massimiliano Cannata wrote:
> I've read somewhere that there are some problem in interfacing
> fortran with C...
> but if you all can run this library....
> there should be a solution...
Does your gcc installation include FORTRAN support?
You need the file g2c.h in order to use FORTRAN libraries such as BLAS
and LAPACK. The body of the file src/libes/gmath/la.c (which defines
the various G_matrix_* functions) is conditionalised with:
#if defined(HAVE_LIBLAPACK) && defined(HAVE_LIBBLAS) && defined(HAVE_G2C_H)
so those functions won't be defined if you don't have g2c.h.
Glynn Clements <glynn.clements at virgin.net>
