[GRASSLIST:982] Re:
Massimiliano Cannata
massimiliano.cannata at supsi.ch
Thu Aug 21 04:50:25 EDT 2003
Glynn Clements wrote:
> Cannata, Massimiliano wrote:
> > Still when i compile my script, i cannot recognize the
> > blas/lapack function. Still get: undefined reference to
> > `G_matrix_init'
> Did you do "make distclean" first?
Yes, I've done more than once this steps:
* make distclean
* ./configure --with-blas --with-lapack .....etc. etc..
* make
* make install
> > I have already reconfigured my grass files --with-blas and
> > --with-lapack option but nothing changed!
> > Any idea?There's nothing i can do?
> > Thanks
> > PS: here is a part of my config.log file:
> The configure checks succeeded, so there is no need to look at
> config.log.
> Glynn Clements <glynn.clements at virgin.net>
I've read somewhere that there are some problem in interfacing
fortran with C...
but if you all can run this library....
there should be a solution...
Thanks a lot.
Massimiliano
Ing. Massimiliano Cannata
Istituto di Scienze della Terra - SUPSI
C.P. 72 - CH-6952 Canobbio (Ticino, Switzerland)
Tel +41 91 /935 12 25 - Fax +41 91 /935 12 09
eMail: massimiliano.cannata at ist.supsi.ch
Internet: http://www.ist.supsi.ch
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20030821/a81f7ca6/attachment.html
