[GRASSLIST:1004] Re: importing coast line data
Ambili Sudhi
ambilisudhi at yahoo.co.in
Fri Aug 22 22:29:06 EDT 2003
Hi Amit,
well i had imported some coastline data into GRASS
sometime ago so might be the same procedure cld be of
help to u its as follows:
1st create a vector ascii file and save it in the
dig_ascii folder of your location (for format of vec
asc chk the help file for v.import).
then run v.import with option 2 to import the vector
ascii file .
nw try and display the coasline using d.vect.
regards,
Ambili.
--- Amit Keney <amit at darya.nio.org> wrote: >
> Hi all
> I wanted to know if it is possible to import
> coast line data into
> grass....
> actually I have imported bathymetric data into
> grass and converted
> it into a DEM . now the problem is that i wanted to
> display the coast
> line in order to show the relative position of the
> data with respect to
> the coast.
> basically what is important to me is the 3D image
> in NVIZ tool . so
> how can i plot the coastline so that in the 3d image
> i will be able to
> show the coast line as well
> Thanking all in advance
> --Amit--
________________________________________________________________________
Yahoo! India Promos: Win TVs, Bikes, DVD players & more!
Go to http://in.promos.yahoo.com
