[GRASSLIST:1011] Re: help needed with importing dxf files and d.labels
Paul Kelly
paul-grass at stjohnspoint.co.uk
Sun Aug 24 15:20:17 EDT 2003
Hello
Ambili Sudhi wrote:
> hi everyone,
> Plz help me out with this problem:
> I have an dxf file created in autocad which has 3
> layers of drawings and 1 layer of text. Now when I
> import this dxf file into GRASS all the layers get
> imported however the when I try to display the text
> layer it does not show the text instead it shows plain
> boxes around where the text is supposed to be.
This is normal. v.in.dxf calculates where the text would be and draws a
box around it.
> The command used to import is as follows:
> >v.in.dxf dxf=/home/gis/Test.dxf lines=0,1,2 labels=3
> prefix=Test
> After importing when I run v.support for the text
> layer file I get the following error in the output:
> Reading Vector file 100%
> Building areas 100%
> Building islands (no islands present)
> Attaching labels
> Bad line 'L 15.945373 7.213136 ELLIPLSE
> Bad line 'L 8.352338 13.325963 CIRCLE
> Bad line 'L 4.482340 7.653259 RECT
That is a known bug in v.in.dxf that might be fixed some time. You can
work around it using the Perl script in this message:
http://op.gfz-potsdam.de/GRASS-List/Archive/msg08556.html
As you have seen above v.support will delete your attribute labels
unless you run the above script first, so you will have to re-run
v.in.dxf. But that is described in the above link.
When all that is sorted out and your labels are in the dig_cats file,
d.vect.labels will be the command you want to show your text labels in
the monitor.
Paul
