[GRASSLIST:1028] Re: srtm
Matt Doggett
mdoggett at coas.oregonstate.edu
Tue Aug 26 14:38:11 EDT 2003
What I usually do is convert a states/countries/landmass shapefile (or
vector) into a grid with ones (1) and zeros (or nulls). I use this grid
as a mask for r.mapcalc calculations.
Matt
Matt Doggett
Spatial Climate Analysis Service
Oregon State University
316 Strand Ag Hall
Corvallis, OR 97331
(541)737-9153
-----Original Message-----
From: owner-GRASSLIST at baylor.edu [mailto:owner-GRASSLIST at baylor.edu] On
Behalf Of Ian Macmillan
Sent: Tuesday, August 26, 2003 11:22 AM
To: Kevin Slover
Cc: grasslist at baylor.edu
Subject: [GRASSLIST:1027] Re: srtm
thanks for the suggestions, I thought of that too, but I don't think
that would
work for srtm data. The data in the oceans is not necessarily negative,
the
values sometimes even get up into the hundreds of meters. It is
actually
pretty difficult to pick out the coastline with that data set. I was
thinking
I might be able to somehow turn to null everything outside of a vector
(or
raster) coastline file.
-Ian
