[GRASSLIST:1034] Re: srtm
Hamish
hamish_nospam at yahoo.com
Tue Aug 26 23:34:18 EDT 2003
> What I usually do is convert a states/countries/landmass shapefile (or
> vector) into a grid with ones (1) and zeros (or nulls). I use this
> grid as a mask for r.mapcalc calculations.
Yes, I've done this too and it works well.
Get your bathymetery data into raster form using:
- s.surf.rst or s.surf.idw from a sites file
- v.to.rast & r.surf.contour from vector contours (or v.surf.rst)
Then use the new bathymetry map as a MASK.
You can use r.mask or r.mapcalc to do this.
The r.mapcalc way might look somthing like:
r.mapcalc landonly="if(ocean<0, null(), land)"
You could also use r.patch to merge the two; indicate preference
for the bathymetry map by listing it first:
r.patch in=bathy,land out=bathy_and_land
Hamish
