[GRASSLIST:1044] Re: gdal problem
Wed Aug 27 10:52:40 EDT 2003
Keith J. Forbes wrote:
> Hi. I am trying to import what I am pretty sure is an Arcinfo binary grid
> formatted file. The file was created from a grid of points in Arcview using
> the inverse distance weighting method. Specifically the command from Arcview
> was Theme|Convert to Grid. The file name is w001001x.adf.
> I installed Grass from sources but recall having difficulties installing gdal.
> I don't recall if I ever installed it or not. The only folder I have with
> gdal is the following:
> (/usr/local/share/gdal)
> [keith at siam1 gdal]$ ls -al
> total 568
> drwxr-xr-x    2 root     root         4096 Jun  6 13:20 .
> drwxr-xr-x   15 root     root         4096 Jul 22 17:20 ..
> -rw-r--r--    1 root     root        73770 Jun  6 13:20 datum.csv
> -rw-r--r--    1 root     root        10735 Jun  6 13:20 ellipsoid.csv
> -rw-r--r--    1 root     root        22351 Jun  6 13:20 gcs.csv
> -rw-r--r--    1 root     root          533 Jun  6 13:20 gdalicon.png
> -rw-r--r--    1 root     root       332781 Jun  6 13:20 pcs.csv
> -rw-r--r--    1 root     root         1599 Jun  6 13:20 prime_meridian.csv
> -rw-r--r--    1 root     root         7254 Jun  6 13:20 s57attributes.csv
> -rw-r--r--    1 root     root        20885 Jun  6 13:20 s57expectedinput.csv
> -rw-r--r--    1 root     root        30680 Jun  6 13:20 s57objectclasses.csv
> -rw-r--r--    1 root     root         9216 Jun  6 13:20 seed_2d.dgn
> -rw-r--r--    1 root     root        10315 Jun  6 13:20 stateplane.csv
> -rw-r--r--    1 root     root        15266 Jun  6 13:20 unit_of_measure.csv
> When I run r.in.gdal (accepting all defaults), I always get "Segmentation
> fault" as an error.
> QUESTIONS:
> Do I need to reinstall gdal? If not, why are my attempts at importing arcinfo
> binary grids (w001001x.adf) not working. Would appreciate any help.
Keith,
Arc/Info binary grid formats requires a directory of files including the
w001001x.adf file.  I would suggest trying to run gdalinfo against the
file to see if the problem is general to GDAL or specific to the way it is
being used in GRASS.
If it crashes gdalinfo then you could either try to debug it via gdalinfo
(if you have the inclination) or you will need to file a bug report
including making the data available.  if the bug is reproducable with gdalinfo
please file the bug report in GDAL's Bugzilla. If it only occurs in the
context of GRASS's r.in.gdal command, you should likely file it against
GRASS.
Best regards,
